stroker
stroker
I'm about to do a 331,so I was wondering if a ford racing cam would still be a could decent choice,or should I look elsewhere for a cam...for now I'm gonna have stock cobra heads and intake if that helps any........thanks.............jason
RE: stroker
IMO i would go with a Comp Cam and get a custom grind espically since you are building a 331 stroker. Plan out all your mods that you are going to put into the engine and tell them and they will tell you the cam you either need or they can grind you a custom one for your application
RE: stroker
You might not even need a custom grind... places like Comp Cams had hundreds of combinations to choose from. Give them a call, tell them what you have and what you are looking for and Im sure that they can find you something. And if they cant (which I doubt) than go with a custom grind.
YoungStangsMan
09-05-2015 07:01 PM
95_GT_Stang
04-10-2004 04:39 PM
