factory igntion module
If i understang correctly an aftermarket ignition box replaces the factory igntion module, correct?
now say my aftermarket box quit working and i want to go back to factory ignition temp. i would take the four small wires that plug into the top of the coil and plug them back into the factory ignition module, right?
if so were would i find that module? i've been looking for it, but i can't find it. i sure hope the previous owner didn't take it out![]
thank you
thank you
RE: factory igntion module
no it doesnt replace the TFI (ignition module) if your igition box failed just unplug
your stock plug where it plugs into the new ignition harness and plug it into
your coil
oh and your ignition module is on the side of your distributor
your coil
breaking
10-02-2015 01:27 PM
