is this a good motor.
Old 01-12-2006, 07:04 PM
da boss
da boss's Avatar
Default is this a good motor.
Hey I am in the planning stages of purchasing and modifying my daily driver. I have been thinking about getting this motor what do u guys think about this company and its quality. It is a few thousand over what i wanted to spend but it is fuel injected with almost everything forged. Does anybody think it might be a little pricy for what I would get. It will be going in a SN-95 GT body and I was going to upgrade:
1.)the suspension with a= new shocks, springs, k-members, and A-arms. (tell me if i would need more than that)
2.)axles=unknown yet
3.)gears=3.73(I think, but would there be a better gear for this motor and gas mileage)
4.)transmission= (manual) TKO 600 w/ .64 overdrive
5.)clutch= Kevlar King Cobra Clutch
6.) chassis= a cage from agent 47 (sports model)
7.)brakes= brembo cross-drilled brakes
8.)tires= Nitto 555 (unknown dimensions)
I would be doing #1-5 at the same time I am going to be installing the motor. #6-8 will probably be installed sometime around christmas of this year.
http://www.fordcobraengines.com/408w_Proflo.htm
da boss is offline
Old 01-12-2006, 07:05 PM
da boss
da boss's Avatar
Default RE: is this a good motor.
I think that is everything
da boss is offline
Old 01-12-2006, 10:42 PM
ben5.0
ben5.0's Avatar
in my eyes, with $13,000 u can end up way BETTER than that.
ben5.0 is offline
Old 01-12-2006, 11:46 PM
schwindty
schwindty's Avatar
No ****, get a Forged internal Dart 351W port the **** outta some trick flow heads Get a Kenne Bell 2.2 L or a Novi 2000 and you will get way more Hp that thing is running with WAY better economy..... Even get a 408 done by a machine shop for cheaper than that..... thats for guys with more money than brains
schwindty is offline
Old 01-12-2006, 11:55 PM
92TitaniumGT
92TitaniumGT's Avatar
I hope those tires are nitto nt555R's?
92TitaniumGT is offline
Old 01-12-2006, 11:59 PM
Crazyfast50stang
Crazyfast50stang's Avatar
I didnt see the link so i kept scrolling down and saw the comment on howyou can do so much more wih 13k. So I scrolled up found the link looked at the price, laughed and closed the window. Can I ask you WTF are you thinking???? Listen to scwindty and everyone else who is AGAINST that motor. The reason the price is so high is because of the name they are PUTTING to it the whole ELEANOR. Forget that. Please do not buy that engine. With 13k you can turbo a engine like schwindty said and get a HELLLLLLLL of a lot more HP.
Crazyfast50stang is offline
Old 01-13-2006, 02:45 AM
Tims 88GT
Tims 88GT's Avatar
first off i see a lot of problems with the way that motor is built like chrome moly rings and push rods, have you ever seen a cylinder bore with chrome moly rings i dont suggest them. i could build a bad *** 347 for a lot cheeper that would kill that thing.
Tims 88GT is offline
Old 01-13-2006, 02:58 PM
TAPOUT
TAPOUT's Avatar
If you wanted to buy a retro look, and not do any work yourself, go ahead and overpay them. I bet I can hang with the power of that engine with mine, and I am less than $7k into it with lots of other upgrades.
TAPOUT is offline
Old 01-13-2006, 03:24 PM
w8less
w8less's Avatar
if ur going to get a k-member spend a little bit more and buy the whole kit that way u get the full benefit out it. then i would recommend buying some upper and lower control arms to help put the power to the ground
w8less is offline
Old 01-14-2006, 12:17 AM
95_302_StangMan
95_302_StangMan's Avatar
13G for that engine, if you want to waste that much money you can send it my way instead. Good luck tho!
95_302_StangMan is offline
Quick Reply: is this a good motor.
