BIG PROBLEM!
BIG PROBLEM!
well i took off my upper intake and put it back on and now i crank it up and it just goes straight to redline and i have to shut it off does any one know whats wrong i guessing its the vaccuum lines iam i right?
RE: BIG PROBLEM!
That could be possible, but Ive never seen a vacuum line make it go straight to redline. Ive seen them make a motor jump a thousand or fifteenhundred rpm's but not that much. I would like to know the answer to this one also...
RE: BIG PROBLEM!
You mention the cruise control, if it's hooked up such that it pulls a wide open throttle, that could do what you're describing. A vacuum leak that large should shut the engine down. Along with air, you've got to have fuel, and a vacuum leak won't give any extra fuel. Check your linkage and make sure you didn't get the throttle in a bind in some way when you went back together. It really sounds like the throttle if being opened. Also, if the throttle linkage looks good, disconnect the cruise from the throttle so that it cannot open it, and then try it.
