destroking a 351
RE: destroking a 351
ORIGINAL: Sinister Audio
ya if you want a V8 you usually dont ever want them to go that high. if you have a 4 banger then you might or a crotch rocket they like reving high.
i just like high reving motors i don't know why i have allways like them., also i allready have a bike it revs to 14,800 rpm. i think bikes are really what got me into high reving i love it. plus i want something diffrent. i will drive it on the street but it will not be my daily driver. i will take it out on a nice day and hot rod it. beteween riding high reving 2 stroke dirtbikes, and high reving sportbikes i just like the sound. but i might end up bulid a 400+ ci motor that revs to 7-8k. this why i'm trying reash. my turbo is a t88 clone it suports 1000horse. and my nitrous system can put out to 250 but i'm planing on just runing a 25-50 shot to help intercool and spool the turbo. and i'm going to run low boost on my current motor.
i run more rpms than that my r/c truck runs 32,000 lol, but anyways, i see where you are comming from high reving motors are cool, but you need to build your 351 like a nascar motor that will get you the rpms you want.
ORIGINAL: AdderMk2
Im calling Bull**** on this one...
you want high RPM's... buy a honda of an RX-7
you want power.... un-rice your thought process!
when u grind a cam, you design it to make power in a specific rpm range. in a high revving engine, it might be 6k-8k. street oriented might be 2.5k-4.5k. in general, torque is low end power and hp is high end power. therefore you either tune for torque or hp. for example, a nascar engine may make 800 hp, but it only makes 500 lb/ft of torque (estimate). a stock 302 makes 225 hp, but it make more torque. a good cam specialist can grind a cam to get try to get the most out of both, but it will never be able to make insane amounts of both (without power adder)
no if you can have a cam that pulls from 1500-6500 than you can get a cam that will pull from 1500-8500, call lunati and tell them you want a cam to pull from 1500-8500 and they will say ok and send one to you, i know i call and asked, the can make anything that you want. my uncle has a comp cam that pulls from idle to 8700 in his 289
ORIGINAL: Melon
