newbie is dumb
newbie is dumb
i just purchased my 88" gt and i have done little things to so fa, but i need POWER i have a couple questions if i could:
the gt 40 install; how hard is it and is there a link to a webpage or past forum to help me out.
wut else could i do to it to make it more street.
i have done.....exhaust, k & n air filter, and some other small things.
any help will be well worth it.............thanx
RE: newbie is dumb
What type of exhaust are you running? Do you mean just a caat-back? When I had my 88gt I had a mac o/r H-pipe and flowmasters. The lack of restriction really let it breath...a set of good headers would have helped even more. Of course you'll have to swap out the original h-pipe to pass inspection once a year, but its worth t...only about 30 minutes worth of work. I also had a b-cam in which really helped as well.
My suggestion would be to replace the heads, upper intake and cam. You can usually by these as a package and save money. If money is an issue buy them used and then take them down to a machine shop and have them cleaned up for about $100 at the right place.
302s are VERY easy to work on and parts can be found cheap if you look in the right places. There not very powerful stock, but once you open them p the sky is the limit! Good luck!
RE: newbie is dumb
dont for get bud you got an 88gt so unless you already converted it to mass air flow dont get to excited about modding your pony....you going trying to throw a cam in a non mass air car you in for some rough work....so check in to all your options before you go spending money on **** you cant use....and good luck with you pony...
RE: newbie is dumb
im in the process of gettin an mass air flow..............i have long tube headers, then a h pipe w/o converters, to staight pipes to the end with a set of tips. my father owns a body shop so work is free. i also have a way around inspection
RE: newbie is dumb
No muffs? I have the same set up, sounds beautiful but there is a big drawback, and that is that there is no backpressure which means no low end torque I hate it and can't wait to get a MAC catback.
RE: newbie is dumb
nothing wrong w/ modding a speed density car.
converting to mass air is not that important.
speed density will run faster all stock anyways.
i would say get some geras...you will really wake it up, a nice jump to 3.73's or 4.10's will feel like about 100+ hp, for $400
get a set of cheaters and you'll run easy mid to low 13's
Calizic
08-28-2015 01:46 PM
