Pulled my Codes now what
01-16-2006, 10:54 PM
I have an 87 GT that is very hard to start when cold. When it does crank it runs like it is starving for fuel. I pulled the codes and I got a 34 and an 82. Any ideas on what these codes mean, or what I should do nowh? Any help on this would be greatly appreciated since I'm in a small town with a very limited supply quality mechanics and it will not run well enough to take to another town. Thanks in advance for any help!!
01-16-2006, 11:07 PM
RE: Pulled my Codes now what
Try google. Type in 1986 mustang GT trouble codes along with the codes you received see if it gives you anything.
01-16-2006, 11:12 PM
Banned
(R) = Engine Running test (M) = Memory code (O)=Key On Engine Off test
34
(R) EVP - EGR did not respond properly during test - EVP
(O,R,M) EVR - EVP sensor is/was high - EVR
(O,R,M) PFE - PFE sensor is/was out of range - PFE
82
AIRB solenoid - Solenoids and Air Injection
hope this helps
01-16-2006, 11:14 PM
34 is egr valve position and 82 is thermactor air bypass
01-16-2006, 11:56 PM
Ok.. does this mean i need to replace the EGR and the air bypass solenoid? Where is the EGR?
01-17-2006, 12:09 AM
It's #50 on the engine map stickey at the top of the 5.0 page. Exhaust Gas Recirculation.
01-17-2006, 01:03 AM
By any chance have you bypassed your air pump. If you have then you will though code 82.
01-17-2006, 02:42 AM
unplug your egr and see if it will start, you will have a check engine light on from the egr beaing unpluged.
01-17-2006, 08:59 AM
Yes my smog pump has been removed by the previous owner. I'm thinking I should remove the EGR too, is this correct. Ok now that I know about the code 82, what should I do about the 34???
01-17-2006, 10:03 AM
Can the thermactor air bypass be removed? Is this still part of the smog system?
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
Urambo Tauro
10-05-2015 09:37 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
