NO START PLEASE HELP!!!!!!!
RE: NO START PLEASE HELP!!!!!!!
your car should have solenoid just like a fox, turn your key on, put it in neutral
then bridge the solenoid posts together w/ a screw driver and see what happens
if it starts your solenoid is bad
i did the nutrual thing a while ago and hit the sinold with the screw driver it cranks over but will not start i even tried to run a wire from the batter to the ingtion wire and my car alarm keeps on going off i know it's that damn ingiton switch i just don't know how to check it myself.
Well I changed the ignition switch and the starter started cranking but not strong enough. After couple of cranks it was back to the same old ****. I have given up I guess I will have to try push starting it and take it to a shop. Anyone else any ideas?????
