WELL I'LL MAKE A POLL OUT OF IT THEN
RE: WELL I'LL MAKE A POLL OUT OF IT THEN
Well give us details about your setup and what you're looking to gain from the new cam
Like is it only going to see it's power all up high?
Guessing you want something that will allow you to rev high as ****, so hyd may be out of the question(you said track car)
What about piston to valve clearance? and all that jazz...
it's a pro bullet with huge reliefs.pro lite pistons main support.
afr 185's 60cc milled .010
rpm intake
accufab 70mm
pro-m 75mm cal. 24lbs inj.
all msd.
underdrives
two electric fans
high volume waterpump/harden oil pump shaft
trick flow push rods
dss 1.6's
powermaster alt/starter
aeromotive fpr/pump
bbk cai
tko tranny full strange rearend with 33 splines
alum drive shaft
subframes
eibach drag springs/airbag
strange struts/shocks
hotschkies (sp) caster/camber
upper/lowers
LT'S
X-PIPE WITH FLOWS DUMPED
rpm intake
accufab 70mm
all msd.
underdrives
two electric fans
dss 1.6's
aeromotive fpr/pump
bbk cai
alum drive shaft
subframes
upper/lowers
LT'S
told ya...that's why i want to move to ky..or new mexico
ORIGINAL: vfast
damn
ORIGINAL: grabbem88
it was always the back/motor side.
ORIGINAL: vfast
oh..so why not put a screen in front of it?
