Mass Air Calibration
I have installed 24 lb injectors and putting in the 70 mm throttlebody and mass air. How is the mass air calibrated to the 24lb injectors? How can you tell if the calibration is correct? Is there something in the mass air part number that defines the injectors it should be used with? Does it really matter??
RE: Mass Air Calibration
You need to get a Calibration tube.
If you are still running the stock MAF it wont work.
Ur going to have to buy either C&L MaF with the 24# Cal tube, or some other after market Maf I think.
daltron
04-28-2016 08:10 PM
