still missing
still missing
ok my car is still missing 4-5k i have done plugs, wires, cap, rotor, ignition module, coil, 02 sensors, removed egr, smog pump removed. ok yesterday i adjusted timing RETARTED IT and uped my fuel pressure to 32. i have 24lb injectors. and it ran fine now it runs like crap again i do not know what it is, i cant find anything wrong, im so stumped.
RE: still missing
Did you block off the ports in the back of the heads where egr and smog was hooked up? Whats you vacuum at idle. Should still be at least 18 unless you lobe seperation is real close.
Also my car seems to miss when it gets to 4k rpm and higher. But my problem is the rubber ring around my harmonic balancer is starting to back out and causing internal vibration at high rpms.
RE: still missing
zach you may want to get that fixed, ok i may have it fixed the sensors on the back of the shock tower for the smog crap, i pluged them back in and it seams to run fine, my fuel pressure is 35 at idle i made it a little higher. i still have the pipe on the back of the heads i have bolts to put in the head but i never got to put them in this weekend, also when i took the egr off i made a block off plate. so as of right now it runs good, tomorrow is another day, thanks for the help
