Heads on speed density
RE: Heads on speed density
I have one quiestion if someone could Answer it.
If you do add a Cam I know it upsets the Vaccum and make the car run crappy. After all SD runs off the vaccum.
When you change the Cam which way does the Vaccum go?
Does it have lower vaccum or higher?
Im trying to come up with ways to keep mine SD as well.
SORRY TO HIJACK POST We were just on the Subject
You lose vacuum. Just keep with a 114 lobe sep. cam and you'll be good. You're problems on keeping it speed density are going to be idle issues due to fuel. When you change injectors problems start. Many people have run 24s with little to no issues but some people do have issues. With 30s or more, you'll definately need a chip burned.
mungodrums
09-29-2015 09:18 PM
musnicki
09-23-2015 07:11 AM
jaiidutch
09-14-2015 10:29 AM
