306 SN95 = 11's ?
RE: 306 SN95 = 11's ?
Im sure it does but I dont know. Also, with the whole gas mileage thing its wierd situation because hes worried about the gas mileage and its not his goal to hit 11's he just thinks hes going to hit it and I dont agree.
NOT gone to happen in my book but thats me.I dont even think it will run mid 12 first few times out. sn95s are pigs sorry.IMO and I dont think he has the right parts to do it but that me....
I say no also...thats alot of weight not to mention that intake is doing nothing but hurting performance...sure it looks cool but with that small of cubic inches and that much weight it was a very bad choice.
ORIGINAL: 88BlueGT
I just have a quick Q fellas. A friend of mine swears that he is going to dip 11's w/ this setup and I dont think that he will. Here it is; let me know what you think.
306 - Compression: I dont know it but its nothing crazy
Trick Flow "R" U/L manifold
CAI
Equal Length BBK's
BBK Mid Pipe ending w/ Flows (I think)
E Cam
Pulleys
MSD ignition
UPR K member, a arms, front coil over
U/L Control Arms
KYB shocks/struts
Trick Flow heads (not sure what heads)
3.73's
Rebuild AODE from Performance Automatic
Full Interior
What do you guys think because I dont think he will make the power. Thanks!
CAI
Equal Length BBK's
E Cam
Pulleys
MSD ignition
U/L Control Arms
KYB shocks/struts
3.73's
Full Interior
Is 11.5 Crazy?
You're also not sure What Heads... Could be making some nasty top end
If he has a good suspension setup, it is possible to dip into some pretty low numbers.
Get a nice sticky tire like some ET Streets I could see him doing some damage.
With just suspension work on a stock foxbody, you can see mid 13's.
Or unless you're 'Quik' you can see low 13's 'stock'.
it's just funny that everybody keeps looking under the hood(which is the wrong place to look)
a decent suspension,and sticky tires,and with his set up might get you low 12's or high 11's?if you can't then you better be looking in the mirror.
