my cars news and couple tech q's
i just ordered a typhoon intake which will be gasket matched, a 70mm throttle body and a 73mm maf, i plan on getting a cam.. maybe like a b cam, will it work alright with my combo??? i am undecided but might be taking the heads off to get them ported also (stock heads) i want to install the cam myself... is it possible when never installed one before??? any instructions..thanks.
RE: my cars news and couple tech q's
But whats the point of a cam with stock heads????So it will sound fast..that's just as bad as putting cobra badges on a 6ixer..And the b cam is VERY quirky..and hard to tune..So i would look into a dual pattern cam like the TF stage 1 cam..Plus its cheaper.
bah if your going to do a cam swap and get your head ported you should really look into thumper porting, he has proven 12 sec combos with stock ported heads for a real good price. his combo #3 is:
ported E7 that are ported, gasket matched, some bowl work, etc. plus
Vassco springs, moley retainers and keepers
For cams to .600 lift
Double roller timing chain and gear set w/3 position key way
FMS "E" ( for AOD cars) or "B" cam
Instructions on installation and Cam phasing for the best power and performance for you application
Proven 12 sec combination
$895.00 + 100.00 refundable core charge**
I had him do some work on some gt40's that i got off ebay and man they look great (there soon to be going in a fresh short block). he's really great to work with and he can basically do whatever you want. here's his link: http://www.hunterstyle.com/thumper/index.php
this might help u out...
http://users3.ev1.net/~voodoostang/headsswap.htm
yeah I agree since your getting in there you might as well just do the heads. If it takes some more time to save up just remember this, all great things are worth waiting for. Tell yourself that for a while and it will help the time pass.
ORIGINAL: 88BlueGT
Sorry but I cant help you (never did a cam swapp) but I can tell you this... if you dont try it sometime you will never learn right ?? Do it yourself.
Someone posted a link, but I would probably try to find a local speed shop somewhere in your area so you can save on the shipping as well.
92 5.0stang
08-13-2015 06:46 AM
Soldier GT
08-12-2015 03:46 PM
Milan Dragway
08-12-2015 03:43 PM
