Need some help on x or h pipe
RE: Need some help on x or h pipe
ORIGINAL: 01SilverGT
SICK as in, nasty, or sounds real good. I've always heard an aftermarket midpipe with stock catback sounds like ****. But hey I guess not.
ORIGINAL: AdderMk2
there IS a tube that runs up to the motor from the exhaust, it connects to the smog pump system. Contact Promustangperf on AIM and tell him that i recommended you to him.
I'm running a BBK off road (no cats) X pipe on my 94 Cobra and with the stock mufflers it sounds SICK.
you CAN connect the aftermarket mid pipe(x-pipe in my case) to the smog system, or you can buy the smog elimination kit... which i'll be getting soon
if you get the smog elimination kit, just block off the tube on the mid pipe. I used a lug nut b/c it was all that i had laying around. i just inserted it in the end of the rubbe tube that came with the pipe and used the clamps included... it held fine for me!
Well you wouldn't have a stock catback they eliminate the cats all you would have is the pipe coming down from the header then the x or h pipe then going into your stock mufflers.
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
