cam help
RE: cam help
ORIGINAL: stangpower96
PUTTING A CAM IN A MOTOR WITH STOCK E7'S IS DUMB AND A COMPLETE WASTE OF MONEY AND TIME.
RE: cam help
here is what i wanted to do, gt40p heads and intake, cam, 1.6 rrs, underdrive pullies, and ram air kit from summit, flowmasters am thunder, or force2, world class rebuild kit the gears are 50% wider than stock, short throw shifter, and subframe connectors. can u help me with any better combo, or point me in he right direction? should i stick with efi or go to carb? im not sure what to do yet, im trying to get as much advice as i can before i tear into it. thanks for the help
RE: cam help
ORIGINAL: Tims 88GT
also FullAuto i want to see the time slip for that one 11.8 in a hatch with a AOD is a lil hard to belive.
RE: cam help
well when you first stated that you ran 11.8 you said nothing about nitrous, so next time you want to brag about how fast you ran you need to give the list of parts that you have done to the car, because what i got out of what you said is you took a full weight lx AOD stock heads with the bump removed and a cam made that thing go to 11.8
