Power Steering Assembly
RE: Power Steering Assembly
ORIGINAL: Blue Oval
Can someone with a manual look up how the spring and check valve go in in the power steering line? Thanks.
What is it, like a spool valve? Spring should go in first, and then the valve, (which should have a screen on one end) goes in with the screen facing out, or towards you....so that it is filtering the fluid as it flows through it. I have never messed with power steering on a Mustang, but every other flow control valve I have seen is assembled like that.
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
09-25-2015 06:58 PM
