Stroker Engines/ 5.0 or 5.8
RE: Stroker Engines/ 5.0 or 5.8
ORIGINAL: Colbypit
what about a 331 stroker??? I wouldnt go 347, unless I was going to race, as the cylinder walls are very thin.
ORIGINAL: mkspeed26
351W. btw those engines look SICK in the engine bay. heres mine
[IMG]local://upfiles/3799/07400DA9E59944B4B8098A1EF3BBE97B.jpg[/IMG]
[IMG]local://upfiles/3799/E4BB97DC73E543D3818D83AF6D92BAF6.jpg[/IMG]
Jim
ORIGINAL: kartracer55
Thats good stuff but get some damn wire loom lol the black plastic stuff. its like 5$ for a million feet of that **** lol
Jim
ORIGINAL: mkspeed26
Jim
a stroked 351W based engine is the way to go for you. running the stock stroke would not be advantagous for you because it is a strip/street engine and you wont be revving to 10k rpms.
I have, and covered it all up. those were just the only pics I could find at the time (notice it is started in the first pic)
I have found out that the 3.25(331) stroke on a 302 is better strength wise than the 3.4 in (347) because both use a 5.4 inch connecting rod and the 331 has a better rod ratio making less side load on the 302 block wich likes to split in half. As for the 351, I here both the 3.85 inch stroke and the 4 inch troke are very good The first being a 393 and the later being a 408. The more I find out and given I wish to drive an all motor set up I think the 393/408 will be a better choice. I found an article where the FRPP 393 with AFR heads made 530 HP at 5800 rpm on 91 gas and made 500 ft lbs of torque in carberated form. Finding that the stroker kits for 302 and 351 are almost the same cost I think I will stroke a 351.
ORIGINAL: SmokumsTheBear
So in order to get to rev to the 10k rpms or so Id have to get what size stroke?
ORIGINAL: FullAuto
The cylinder walls are the same with a 331 or 347. They are both 4.030" bore. The difference is the stroke.
ORIGINAL: Colbypit
ORIGINAL: Colbypit
yes your correct, what I ment to say was that, with the 347, the wrist pin is located up into the oil ring, which can cause some oil use, the 331 wrist pin is a bit lower. but now come to think of it, didnt they correct this problem??
And there was a HUGE thread on corral about the rod ratio arguement and the 331 lasting longer. Cliff Notes: It's all BS and no one can prove the 331 will last longer.
