smog pump emissions
Old 01-31-2006, 06:56 PM
Mustangkiler
Mustangkiler's Avatar
Default smog pump emissions
will i be able to get threw and then pass emissions with no air/smog pump on my 94 mustang gt with flowmaster exhaust and stock engine cept wires n plugs n distributor and cold air intake?
Mustangkiler is offline
Old 01-31-2006, 07:12 PM
Blue Oval
Blue Oval's Avatar
Default RE: smog pump emissions
do you have cats?
Blue Oval is offline
Old 02-01-2006, 12:41 AM
Mustangkiler
when i get emission tested they are on, but not any other time.
Old 02-01-2006, 12:43 AM
Blue Oval
Blue Oval's Avatar
you should pass. or at least i hope you pass because i dont have a smog but i do have cats and its inspection time in a few months heh
Old 02-01-2006, 01:00 AM
philthy89fifty
philthy89fifty's Avatar
you won't pass visual.
philthy89fifty is offline
Old 02-01-2006, 01:02 AM
Blue Oval
Blue Oval's Avatar
thats if he has one, i dont
Old 02-01-2006, 12:42 PM
DonovanM
DonovanM's Avatar
Would removing the smog pump create any funny smells behind the car? I'm not worried about passing inspection (yeah it costs me an extra $60, but oh well), but I don't want to hand myself over either. When removing the smog pump, is it as simple as replacing it with an eliminator pulley, or is there some other work that has to be done as well?
DonovanM is offline
Old 02-01-2006, 01:47 PM
FoxRod
FoxRod's Avatar
You can either use an eliminator pulley or just buy a shorter belt and route it while deleting it. You will need to plug up the lines coming out of it. There should be one going to your exhaust I believe and one that goes to the hard line behing the heads. You'll have to plug up those two lines but thats it.
FoxRod is offline
Old 02-01-2006, 02:46 PM
HACKGT350
HACKGT350's Avatar
i just relized the other day that the hose from my smog pump to my exhaust was cut and its not plugged is that a bad thing what will that do to my preformance?
[IMG]local://upfiles/28839/39E29348A44D48CE871F23F2D843BFFD.jpg[/IMG]
HACKGT350 is offline
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
Bokeo
10-10-2015 08:28 PM
Teddi
09-29-2015 12:24 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: smog pump emissions
