combo question
combo question
my new combo will consist of holley systemax heads,vortech intake,x303 cam, 24 lb injectors, 75mm TB,underdrives,no air or smog,bassani x,and flowmasters(dumped).I will also have alot of suspension work(subframe connectors,4cyl springs in front,90/10s,50/50sc control arms, and prolly strut tower brace)...what kind of horsepower should i expect and maybe what kind of times at the track with et streets and 4.10s..last year i was 1.71-1.75 60'..the car is also a 5speed...if anyone has any idea on numbers or any suggestions please post it...thanks
RE: combo question
because eveyone asks the same questions all the time and it gets old, sry if i come off sounding like a butt hole but its true, heads, good cam, intake, tb, maf, pullies so on and so forth on a good short block with good compression you are looking at 270-350 depending on how it works togeather.
RE: combo question
ORIGINAL: slow93pony
add a mass air meter to that list. (75mm)
also there are better heads out there than the holleys. (afr, edelbrock)
do you have a link to that vortech intake?
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
