89 5.0 in a 94 v6??
RE: 89 5.0 in a 94 v6??
ORIGINAL: will
I have a 95 v-6, now a 5.0. you need a bellhousing out of a 94/95 5.0 only 87-93 is 5/8 inch shorter input shaft and bellhousing, the 94\95
is longer to accomidate the new body style interior and shifter placement.
The v6 has a 11" clutch and flywheel the v8 has 10.5"
The computer system DOES NOT plug in, the sn95 body is OBD II where as the fox style is OBD I you have to wire in the new computer and harness, and all the gauges will work right.
The fuel lines have to be legnthened-plastic good luck
Exhaust system has to be from a sn 95 style including headers
If your wandering the a/c compressor will not workfrom a fox unless you have the hoses specially made
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
