Mass Airflow, Need Help Bad!!
All right guys, I just ordered the B303 cam. Now here is my next question, I am using the intake off the Explorer which is the GT-40 I want to go to a bigger MAF, I think a 70mm MAF with a 65mm throttle body would work fine. But I don't think it is as simple just plugging in the new MAF. Can someone tell me what is involved with going to a higher MAF. My car is an 89 GT with a factory MAF. Also does anyone know what size the MAF on the 97 V8 explorer is. I have one leftover from a 97 Explorer V8. Please Need Help
RE: Mass Airflow, Need Help Bad!!
It should be as simple as plug and play. Why dont you go for a 70mm tb? I see your in long beach which is pretty close we should all get together sometime and go down to a race track. There are a few more people on this forum from around here that might want to go. God luck with the mods. Also where did you find the explorer at?
for your mods a 65 is fine
maf from that exploere i believe is ODD II which wont work
i have a C&L 76mm with tube never used for sale calibrated for 30#s but you can buy a tube cheap
I Guess I will Bump Up To 24# Inj. as the build gets there. How do i calibrate the MAF. I really want to learn more about the MAF System what is a good source?
ORIGINAL: Crazyfast50stang
Well I'm From Long Beach Originally But I'm In Oak Ridge Tenn. For The Past 4 Years. I bought the Explorer Engine Here In Oak Ridge. My car was Running Great. Then My Radiator Busted. I took the radiator out and figured now would be a good time to go and put my headers and X pipe since they sat in my shed close to 2 years. Everything came together great had no more mods planned except a 3.73 gear. Like a week later a day after getting my flowmasters put on, the car lost compression on the # 3 Cylinder. All the other cylinders were pushing 111-115 PSI, the # 3 had a whole 25 PSI. Buddy told me it might just be a valve instead of a ring since the car was not smoking real bad. I decided to go ahead and find a whole 302 so I could get the car running but still have a block left over to build in to a stroker engine while still driving my Car. Engine cost me 350.00 bucks the junk yard pulled and loaded it for 50.00, explorer only had 107,000 miles.
