Alternator question.
Old 02-04-2006, 08:31 PM
DJ19895.0
DJ19895.0's Avatar
Default Alternator question.
I just bought a 1988 mustang gt, and when you have the head lights and fog lights on and the heat on hi, the voltage drops to where it is using a little power form the battery. (I tested it with a voltmeter) When you bring the rpm's up to about 1500 or above it resumes charging. Is this normal, is my alternator going bad, or could i possibly have underdrive pulleys? What would the diameter of the alt pulley be if it was an underdrive? This is not a big problem because even after night driving, it starts fine and the battery remains charged. Just thought i'd ask and be on the safe side.
DJ19895.0 is offline
Old 02-04-2006, 08:59 PM
marx91
marx91's Avatar
Default RE: Alternator question.
whats the volts at idle? head lights are a big draw on your battery anyway
and it is possible you have u/d pulleys, i went to a 130 amp alt.
b/c of my electric fan and under drive pulleys, stock alt. is 75 amps
marx91 is offline
Old 02-04-2006, 09:08 PM
SmokumsTheBear
SmokumsTheBear's Avatar
Off topic, but Marx, where could I buy a higher amp alternator? Mine got wet today from going through a puddle. Now I have a number of issues.
SmokumsTheBear is offline
Old 02-04-2006, 09:15 PM
marx91
marx91's Avatar
the one i have came from pep boys, its for a '94 gt
marx91 is offline
Old 02-04-2006, 09:19 PM
SmokumsTheBear
Ah, sweet. Ill have to swing by there tomorrow. Thanks. I also have this Lightweight aluminum pulley for the alternator. Would it be wise to use that with a new alt?
Old 02-04-2006, 09:23 PM
marx91
marx91's Avatar
yeah, but you'll have to cut the big plug off, it has 2 black 10 ga. wires w/ orange stripes
and a white wire w/ a black stripe, then get a ring lug and double crimp the 2 black
wires together and put a spade connector on the white wire and it plugs into the top
of the alt. thats your voltage reading.
*edit* i got a long battery cable and ran it from the alt. over to the solenoid as well
marx91 is offline
Old 02-04-2006, 09:32 PM
silver91gt
silver91gt's Avatar
I got rid of those small stock wires and just used some 4 gauge wire to the solenoid.
silver91gt is offline
tmdm
05-02-2021 02:49 PM
4cylinderplus2
10-09-2020 07:45 PM
Golfsito
10-06-2015 11:02 AM
Daddys Girls GTs
09-14-2015 08:46 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: Alternator question.
