Heads which ones?
Old 02-05-2006, 04:23 PM
FullAuto
FullAuto's Avatar
Default RE: Heads which ones?
The CNC TFS heads from Summit are TEA heads. Brian Tooley is now on their payroll.
FullAuto is offline
Old 02-05-2006, 08:01 PM
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
TFS has come out with there own CNC ported 185 cc heads for the small block Ford. These have the valves slightly rotated in the chamber making for more piston to valve clearance.
But you still need to have the pistons notched.
Which is why I don't buy from Summit either.
Grimace5.0 is offline
Old 02-05-2006, 08:12 PM
FullAuto
FullAuto's Avatar
ORIGINAL: Grimace5.0
Not on a stock shortblock. They are only 2.02" valves and the TW design will fit a 2.02" valve on stock shortblock.
BTW, this is a moot point because that's way too much head for this car.
FullAuto is offline
Old 02-05-2006, 08:31 PM
crazyhorse
crazyhorse's Avatar
i have the tfs-tw heads on my mustang & really like them. no fitting problems. the 2.02 valves does clear the pistons unless you run a huge cam. good luck .
crazyhorse is offline
Old 02-05-2006, 08:37 PM
Tims 88GT
Tims 88GT's Avatar
its not so much the lift that inter fears its the duration how long the valve stays open. the tfs tw heads are the only heads out there with the 2.02 valve that will work with the stock pistons, like stated before it is because the valves are rotated. more towards the center of the chamber.
Tims 88GT is offline
Old 02-07-2006, 12:29 AM
tinman
tinman's Avatar
TFS-TW's.
Be careful about any porting because you can wind up more more head than a 5.0 can use............
tinman is offline
Old 02-07-2006, 04:54 PM
gspfunk
gspfunk's Avatar
I just noticed you're running 30# injectors...seems like a lot for the combo you're running...even w/ new heads 24's should be more than enough.
I'd go w/ the Twisted Wedge.....try to find some used ones. You can usually save some $ that way.
gspfunk is offline
Old 02-07-2006, 06:57 PM
88BlueGT
88BlueGT's Avatar
EBAY.... thats what its there for
88BlueGT is offline
Old 02-07-2006, 07:51 PM
TastePAINt88
TastePAINt88's Avatar
30# should be fine, it sounds like he will use them up soon enough, as long as he gets tunes when he does a bunch of little upgrades or at each big upgrade, the 30#s will be good. Its overkill, but they are usually the same price as 24#s and if you might
exceed the 24#s its a good idea to just buy the 30#s, youll save yourself a set of injectors and the time installing them.
ORIGINAL: gspfunk
TastePAINt88 is offline
Old 02-07-2006, 08:15 PM
91stang
91stang's Avatar
http://www.allfordmustangs.com/Detailed/630.shtml
CHECK THIS OUT... THE RESULTS WILL SURPRISE YOU
91stang is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Heads which ones?
