Transmission lube or fluid??
RE: Transmission lube or fluid??
Exactly, this is a very simple operation. I just did mine a little more than a week ago. You dont have to use dexron II either, you can use virtually any ATF fluid you want, but i would recommend a fully synthetic type like Royal Purple's Max ATF or Lucas' Sure shift semi synthetic. There are a pair of plugs on the passengers side that accept a 3/8" ratchet, (one for drain and one for fill obviously). Dont torque the **** out of the plugs when you reinstall them though because i've seen them strip easy. I have an ATF transfusion pump at my shop and it took me all of about 10 minutes to do this, but if you dont have a pump, then it will be necessary to remove the shifter to refill the tranny. It will accept 5.5 pints of fluid.
ORIGINAL: silver91gt
or just use the fill plug on the passenger side above the drain plug.
you need some kind of pump though.
jwog666
12-27-2021 08:09 PM
09-25-2015 06:42 PM
