MAF Screen
RE: MAF Screen
The maf converts the amount of air drawn into the engine into a voltage signal. The ecm needs to know intake air volume to calculate engine load. This is necessary to determine how much fuel to inject, when to ignite the cylinder, and whent to shift the transmission.
There are different types of MAF's. the vane air flow meter and the karmen vortex are two older styles of air flow and the new one is the Mass air flow sensor (MAF).
All of this information was powered by google
RE: MAF Screen
i wouldnt get rid of it, i have the speed density version, 88 gt. i dont have the mass air flow and im getting close to getting it, your car seems to run better with it, so i wouldnt remove it.
RE: MAF Screen
Disregard all the above posts, they are WRONG, the screen is there as a filter, incase debris get by the air filter. No It will not effect your car running lean or rich. Take that screen out, its basicly causing you too loose a very small amount of air flow and its also causing turblance in the air which is slowing down the air flow, its probally worth about 1hp. I cant believe there is 4 posts and no one answered his question or answered it RIGHT...
RE: MAF Screen
There are no mods listed so I don't know where we are starting from. In stock form, it most likely will make no difference with removing it. If you have mods, and have done any tuning with the screen in, you will need to retune because the screen can effect the air flow and what the mass air meter "sees" as air flow.
RE: MAF Screen
ORIGINAL: 90Mustangfan
btw its called a honeycomb
RE: MAF Screen
Thank you turbostang. I was just going to post the same thing. It is as course as a window screen....no way is it going to catch debris small enough to protect the engine. The screen is there to slow down and straighten the flow into the MAF chamber. Think about the flow through a pipe with bends in it...it is not uniform. There may be more flow in one cross sectional area. If this were the case the MAF would not be able to read the flow correctly. The higher the velocity the more likely that the flow pattern will be uneven. Leave the screen intact.
