<DIV>I'm purchasing a set of replacement heads for my 93' Mustang. They are a stock head with a bunch of work done to them. The valve openings are as follow: 1.94 1.60 with a full port and polish to the exhaust chambers and they are a 64cc combustion chamber. I'm also running a E303 cam, do you think I will need to fly cut the pistons? I hope not because I don't feel like yanking the motor.</DIV>
<DIV></DIV>
<DIV>
Thank you,</DIV>
<DIV></DIV>
<DIV>John <IMG src=smileys/smiley10.gif border="0"></DIV>
easier to change cam and push rods, rockers to mke clearance if poss. fly cut pistons are not a good idea, if needed get new pistons made to work wit setup.
I was thinking about another set of heads. The guy I bought these from said he thought they were around 58 to 60cc. Is that better? How much room should there be between the piston and the valve?</P>
