power numbers...
power numbers...
Well at the end of the month i am having a cam, heads, and a aftermarket intake installed and i was just wondering what numbers i'll likely be making. I am also having it professionally tuned so it will run fine then a couple weeks down the road ill be getting a bigger throttle body, mass air, 24lb injectors, an adjustable fuel regulator, and a custom burnt chip.
Mods after install-
Trick flow track heat heads
Trick flow track heat cam
Trick flow track heat intake manifold
3:73 gears
u/d pullies
mac o/r x pipe, mac catback, mac equal length shorttubes
new valve springs, 1.6RR, and hardened pushrods
Mods after install-
3:73 gears
u/d pullies
RE: power numbers...
Dude you might as well wait and get the injectors and all of that then get a tune, unless he is willing to tune it again after you get those mods.
300-ish for sure. don't bother w/ a tune til you upgrade all the fuel. it won't do anything for you.
if you hook, you'll be in the 12.80 range for et.
spray 100 on top of it, and you could see 11's
