93 5.0 with nitrous
93 5.0 with nitrous
i have a 93 5.0 mustang basically stock right now besides 373 and full exhaust my questions were im getting my tax check and i am wanting to put nitrous on it i am buying the typhoon intake bigger throttle body mass air i am wanting to spray it with between a 50 to 75 and very rarely a 100 i am just wandering what fuel up grades i would need to make and also how the timing should be set up and also if i need to bye the msd boxes for more sparks so i don't foul the plugs and is it safe to run 100 on my car considring it has hyperteck pistons thanks
chris
chris
RE: 93 5.0 with nitrous
little more about what i plan on doing like i said my car is a 93 it has 70,000 original miles now it is a weekend driving car in the summer and it goes to the dragstrip accasionaly on wendsday i plann on doing the nitrous like i said but also in the next 2 weeks im ordering weld racing wheels the 5 star ones with cookie cutters on front and 8 inch ones in the back with MT drag radials im also ordering launch springs, drag shocks, rebuilding my tranny puting a new clutch in it i deleated the air conditiong the smog pump maybe the powersteering but not sure yetim also getting the typhoon intake 70mm throttlebody, massair,fuel pum and a few pressure reg,... so i need to know if i need a bigger fuel pump if so what size also i need to know what timing should be set at and how much fuel pressure i should run and also if i need a msd box,... well those are my plans tell me what you think
yes the myth about hypers and nitrous is a myth. nitrous doesnt kill motors its users. denotaion is why hypers have that myth. they wont hold up as well with denotation but if you experiecne denotaion chances are you got more things to worry about then pistons. hypers are in lightnings and running how many psi? they are the pistons used by most manufactors lately
ORIGINAL: hotstang97gt
even with out the forged pistons?
ORIGINAL: Quik
you could run 100 shot all day long for along time and not have anything to worry about.
ORIGINAL: Aikin9350
how much timing can you run now? then back 2 degrees per 50hp of nitrous. hyper pistons will be fine as long as you dont get greedy "125hp or less" add a bigger fuel pump"155lph or bigger" and adjustable regulator for tuning.
