Q about AOD w/ 4.10s
Old 02-09-2006, 02:23 AM
5.0FoxBody
5.0FoxBody's Avatar
Default Q about AOD w/ 4.10s
Alright...so I had my 4.10 gears put in while back (which I LOVE I might add...even though I run like...3k rpms on the highway) And I can really feel a difference. I do have a slight problem though. The rpm's go up quicker (of course) but when it shifts out of first...like if I'm just accelerating 'normal' it seems to shift from 1st, straight to 3rd...sometimes goes into 2nd gear for like...a second... Is this normal? Other people have this type of thing goin on? Or could it be...maybe a Modulator Valve??? I dunno...lend me some knowledge...
5.0FoxBody is offline
Old 02-09-2006, 07:51 AM
rsw007
rsw007's Avatar
Default RE: Q about AOD w/ 4.10s
might need to adjust the tv cable a little bit.
rsw007 is offline
Old 02-09-2006, 09:11 AM
1BADASSLX
1BADASSLX's Avatar
mine dose the same thang!
1BADASSLX is offline
Old 02-09-2006, 09:25 AM
angcobra
angcobra's Avatar
ORIGINAL: 5.0FoxBody
Sounds like time for a shift kit.
angcobra is offline
Old 02-09-2006, 11:04 AM
92hatchLX
92hatchLX's Avatar
Get a shift kit and adjust that tv cable! Trust me, the shift kit is well worth it.
92hatchLX is offline
Old 02-09-2006, 12:07 PM
88BlueGT
88BlueGT's Avatar
+1 http://store.summitracing.com/defaul...h.asp&N=400214
88BlueGT is offline
Old 02-09-2006, 12:32 PM
Octane
Octane's Avatar
Anybody experience if an '04 has the same problem? I still have yet to find a shift kit for an '04 Mach. Or are shift kits not needed? Heh...
Octane is offline
Old 02-09-2006, 10:18 PM
IWILLRUN_91
IWILLRUN_91's Avatar
OK I had 92 with 3:73 and i had the same problem but come to find out when your driving start in first then go into drive and bring it right back down into first. That will be second but you come to a stop make sure you are in drive or it goes right back into first. Its a shock the first time or just buy a ratchet shifter.
IWILLRUN_91 is offline
Old 02-09-2006, 11:00 PM
93stallion302
93stallion302's Avatar
Mine does the same thing its a 93 wit stock gears tho. mine takes off nice and sometimes bogs done cause it goes str8 2 3rd
93stallion302 is offline
Old 02-10-2006, 12:41 AM
5.0FoxBody
5.0FoxBody's Avatar
I actually have a Transgo Shift kit (AOD-HP) w/ the High Rev kit...but i went to see how much it would be for installation...and the guys said.."Eh..I'd probly do it for ya...for around..$375" I was like...DAMN..f' all that jazz...that's too much just to put a damn shift kit in...so I was thinkin bout re-selling the shift kit...should I check other places? Or is that price about right? :|
Quick Reply: Q about AOD w/ 4.10s
