Vibration Between 2500-3500
I have a 1988 gt and at around 2500-3500 rpm's there is a vibration. It smooths out at about 4500 and up. It is not too bad, but it is enough to shake some interior plastic pieces. I was wondering if this could cause some severe engine wear or if i just need a new harmonic ballencer or if I am just being way over protective with my car all together. Thanks!!
RE: Vibration Between 2500-3500
I was told by a friend with a similar situation that he replaced the driveshaft with an aluminum driveshaft and it resolved the problem. I would be interested to know if others have had similar results.
ORIGINAL: DJ19895.0
Is the vibration only when driving? How about when theres no load, meaning when not in gear.
Does it Vibrate when you rev it up when staying still?
If it does check your motor mounts, Balancer, and maybe Tranny mount.
ORIGINAL: DJ19895.0
If its not a crossmember or motor mount, could be your Harmonic Balancer(don't pull a tire off looking for it) could be a broken or bent fan blade, could be your flywheel, belt tensioner...could be alot of things.
ccdguy
09-19-2015 05:20 PM
