I am having a problem
okay, so I was putting on my new BBK 65mm throttle body yesterday. I can't get my tv cable to attach to the throttle body. Has anyone had this problem before. I thought maybe the hole on the new throttle body was a little smaller maybe, so I decided to sand the **** that goes into the hole. Well I have been sanding for a while, and still no luck. Is there like a secret to this or something. Or is the hole just that much smaller than the hold on my old throttle body? Thanks for you help. I know this post probly sounds confusing.
RE: I am having a problem
Sometimes they can be a little tricky. Does the ball on the end of the new t/b look bigger. It wouldn't take much for it not to fit. Only a few thousanths of an inch. Try some grease on the ball and maybe a pair of needle nose to squeeze them together.
Good luck.
Good luck.
stangin1996gt
09-21-2015 11:01 AM
