StangSuspension.com Handling Package Stage 1
i am looking to get a the StangSuspension.com Handling Package Stage 1 for $420 includes shipping. you all think this is a good deal, the kit includes:
* Steeda Sport Springs - To lower the car 1.25 inches, and provide increased cornering and turning performance
* StangSuspension.com Caster/Camber Plates- Helps align your Mustang after lowering. Also replaces the factory rubber strut mount bushings with StangSuspension.com's high performance spherical bushings
* Offset Rack Bushings - Urethane rack bushings to help increase steering response. The offset feature helps reduce bumpsteer after lowering your Mustang.
* Front and Rear Spring Isolators - Urethane isolators to increase suspension stiffness. Replaces the stock worn out rubber isolators.
thanks
thanks
RE: StangSuspension.com Handling Package Stage 1
thats a good kit but the eibach kits look alot better... thats what im getting but they will set you back a good bit more.... i think the eibach spor kit is about $900.... but it comes with shocks, struts, sportline springs, and front and rear anti roll bars..... all you need to get then is a set off caster camber plates..... but if you already have good shocks and struts that would be a good kit that you are lookin at....and its cool cause you can upgrade it in stages
i was looking at the eibach but that kit is out of my price range for now.
stang suspension recommends the steeda springs and the stage one kit comes with bushings, isolators and C&C plates.
i do like the stage upgrades too, it is an awesome idea.
yea it is.... i just want a kit with the eibach springs and thats the only kit that comes with them...... and i need new shocks and stuts so thats another plus.... all i need after that is c&c plates and rear upper an lower control ams and i should be good...
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
09-25-2015 09:06 AM
mungodrums
Suspension
09-24-2015 10:12 PM
