E303 ford racing cam q?
hey all i was wondering how much of a diff im going to notice if i put this cam into my 86 mustang gt i have a 347 with stock heads and cam
RE: E303 ford racing cam q?
well stock heads can only do so much, but i would change the valve springs at least
so you dont end w/ valve float, but you'll have a much better gain w/ aftermarket heads |
ORIGINAL: 86_GT_5.0 hey all i was wondering how much of a diff im going to notice if i put this cam into my 86 mustang gt i have a 347 with stock heads and cam 302 parts will make 302 power. you should put some heads on that thing. you will see a much bigger benefit than swapping the cam. |
I agree w/ the above about the heads and valve springs, but also look at the TFS stage 1 cam. I have the E cam now, but I'd have gone a different route if I'd researched it more.
yeah the only problem is that i dont have the money for a good set of heads right now so but if i was going to get them what would you guys go with with the engine i have on the lower end im not into engine stuff all that much as im a trans guy thanks
the E6SZ heads are great for torque....and nothing else, I could not even give a pair away
If you still have speed density its no going to like a cam being put it.
ORIGINAL: ZachW04Stang If you still have speed density its no going to like a cam being put it. |
I wouldnt waste the time & money on a cam swap... save it and get head.
