Do you have to swap the rear?? - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Reload this Page >
Old 02-13-2006, 04:42 PM
jayc283
Default Do you have to swap the rear??
ITs me again with the 4cylinder....when u swap to the 302 or bigger im pretty sure u have to swap the tranny but do u have to swap the rearend i have the 7.5 i think do i have to go 8.8 please someone out there help ??
jayc283 is offline
Old 02-13-2006, 04:55 PM
ben5.0
Default RE: Do you have to swap the rear??
yes. from what i understand, 7.5 inch wont hold up under the increase in horsepower. the 8.8 is a must
ben5.0 is offline
Old 02-13-2006, 05:16 PM
4eyedfreak
Thats not true because depending on the power of the engine swap a 7.5 with whatever stcok gear could hold. The 8.8 rearend houses a more circle gear which is better than the 7.5 which houses a more oval gear. To save the money, unless your really going to build the car, i would just get 3.55's or swap out the gear in the 7.5 to whatever, they do make gears for the 7.5. My 83 had a 7.5inch with my stock v8 5.0. The only reason why i got an 8.8 was because i bought the whole rearend fullybuilt for cheap....And i mean cheap. I hade it checked out by a driveline shop and they refreshed everything and i had a brand new fully built strange rearend.
4eyedfreak is offline
Old 02-13-2006, 08:10 PM
hotstang97gt
it will hold but im not shure on how long though. might as well just get the 8.8. where abouts you located? i have one that i will let go for cheap
hotstang97gt is offline
Old 02-13-2006, 09:51 PM
BADNOTCH
You can get a 8.8 housing and install the axles out of your 7.5, they are the same axles, you will just be runnin a bigger ring gear. I have had a 7.5 hold up to a pounding. If you run across a good deal on an 8.8 pick it up, until then put a gear in the 7.5 and run it till it breaks.
BADNOTCH is offline
Old 02-14-2006, 06:04 PM
jayc283
Garland tx is where im at....thanks guys
jayc283 is offline
Old 02-14-2006, 07:51 PM
hotstang97gt
im shure shipping would be alot to ship it out there so i guess you wouldent want to. if you looked into want ads im shure you could find a good deal. good luck
Ryan Fitzpatrick
09-14-2015 03:21 AM
97SN95GT
09-13-2015 10:45 PM
Dragonus18
09-09-2015 02:21 AM
Quick Reply: Do you have to swap the rear??
Featured Sponsors
