Sub Frame?
Sub Frame?
I am having the subframe connectors welded on and the they dont lay flat on the frame....theres gap in the middle. I am having the shop bend then so there is no gap inbetween...is that normal?
RE: Sub Frame?
in the supplied instructions with mm's sub connectors it said you may have to bend it. we had to bend mine a little bit, just heated it with a torch and applied pressure with a hydraulic jack. so yes, this is normal
RE: Sub Frame?
my car had a little twist..i'm using bbk's...and i had a little gap so i used a jack to hold pressure...my car is stiff now
but if you have alot of twist...i'm not sure i'd advise that
