Would this kit work??
is this really all it would take to convert from 4 lug to 5 lug?
description:
The most economical and comrehensive kit on the market! Kit includes 2 five lug front rotors. 2 five lug rear axles and drums, 2 inner and outer front wheel bearings, 2 front rotor grease seals, 2 axle bearing and seal kits, 1 bottle of friction modifier, and 3 bottles of Royal Purple 75W90 gear oil. This kit has EVERYTHING you need to convert to 5-lug the right way!
description:
RE: Would this kit work??
yeah, new wheels, too. That's it if you're staying w/ drums in the rear, but most people go w/ discs when they do the swap. The only advantage you'll have (w/ that pkg.) is a larger wheel selection.
the rear disc conversion will cost more......
ORIGINAL: GreenHornet92
is it even worth doing the 5 lug conversion. I would think so because the 5 lug can handle more power than the 4 lug can. Am I right or can the 4 lug handle enough power?
your wheel choice is very limited with that conversion, some wheels wont allow to put a center cap on them, some will. So research what wheels your going to buy then go from there
the wheels i really like are the old style Crager S/S rims but then I saw the Boyd's Smoothies II in a 4 lug. I know I want that style for sure but just trying to see which is going to look better.
