Lakewood shocks
Lakewood shocks
I'm looking at getting a set of Lakewood shocks all around, What would be the best ratio to get for a daily driven drag car; the 50/50 rear, 90/10 front or the 50/50 rear with 70/30 front? Will these work well with my Eibach Drag-Launch springs? Also can you remove the quad shocks in the rear and just run the one set of shocks without any problems? Thanks as always for the info.
RE: Lakewood shocks
The 70/30 would be better for a mostly street driven car, and the 50/50 will be fine on the rear..Also if you get a good set of U/L control arms the factory quads shocks are no longer needed..But with the factory control arms i would not recommend removing them unless you want to experience some outragous wheel hop from time to time.
