sweaking noise
sweaking noise
when my 89 5.0 notch is idling or moving, there is a noise that sounds like a sweaky belt coming from under the car. if i put a tiny bit of pressure on the clutch pedel, its goes away. anyone know what this could be? thanks
RE: sweaking noise
so what should i do? i planned on getting a new clutch sooner or later, so if im droppign the trans i might as well. what is a good clutch for minor engine mods and a heavy foot? also, what caused the throwout bearing to go? i consider myself pretty good at driving a stick...
RE: sweaking noise
ORIGINAL: ckyguy68
The bearing is a sealed unit. They just go bad after a period of time. Some last longer than others.
RE: sweaking noise
dammit i was hoping it was just an adjustment... it did kind of make sense though. i put a little pressure on the clutch it goes away, if i adjust it that way, its goes away.... right?
