abs light on why?
abs light on why?
I have a 94 cobra and the abs light has been on for about a month now, i pulled the calipers to see the brake pads and theyre kinda low, thats the only thing i can think of, it stops fine. what else could it be?
RE: abs light on why?
ORIGINAL: 94Cobrakid16
if your abs light is on then you have a hole in your vaccume hose for your breaks. happened to our 2005 truck you can drive with it but your tires will lock up when you hit the breaks hard instead of what the abs is ment to do pallsate the break pettle or w/e
ORIGINAL: bigmudder
well, i never thought about it getting scanned, i know somone who can do that. thanks for ALL the info.
Ya what ever the hell you say PRO50SC that might not be the correct wordage but there is vaccum lines for your abs or well speed sensors with vaccume lines that will trigger the abs light to come on if punchured so i might not of said it the right way but i know what the hell i was talking about
ORIGINAL: bigmudder
The abs is controlled electronically, hydraulically not by vaccuum. Try some research. The only thing operated by vacuum is the brake booster. It will not trigger the light.
Click the links and learn!!
http://www.carcare.org/Industry/pdf/BCCABrakeill.pdf
http://www.carcare.org/Brakes/abs.shtml
Which one of the guys in the pic below is you!!!
