Boost gauge install...
RE: Boost gauge install...
ORIGINAL: AdderMk2
running a boost guage is not very difficult... like everyone else has posted you CAN run it from the vac tree... to get the most accurate feed it is best to take your source from as close to the TB as possible. another thing you can do to make your guage as accurate as possible is to use a section of metal brake line instead of rubber hose, the brake line will not expand and contract like a rubber hose will. it also will not deform under small amounts of external pressure(like running it through the firewall.
i use a section of brake line for the BOV in my turbo Probe, and i did notice a much crisper responce with the metal line
ORIGINAL: 1991_5.0_Convertible
So is that going to be measuring boost, or vacuum if you run it off of the vacuum lines???
jwog666
12-27-2021 08:09 PM
Galactic
04-29-2019 02:56 PM
andrew1969
16
01-08-2016 02:48 PM
