Summit Rebuild pics
Old 02-18-2006, 12:32 AM
ZachW04Stang
ZachW04Stang's Avatar
Default RE: Summit Rebuild Kit Arrived. Hell Yeah!!!!
ORIGINAL: JD1969
ORIGINAL: ZachW04Stang
I learned to use plastigauge when I was in tech school. We used it on our engines to measure main and rod journal clearances. The stuff really works well.
It's OK but I would rather use a dial and a mic. Is this your engine assembly? If so I highly reccomend that you find a person who has done it a few times to help you along.
We learned to do it with micrometers also. I didn't do it on my engine, I didn't even have the car then. We did it on chevy 2.5l's. I don't see why plasiguage wouldn't be accurate though. If you torque everything to correct specs and in the correct sequence then the plastiguage should measure accurately.
ZachW04Stang is offline
Old 02-18-2006, 12:37 AM
Tims 88GT
Tims 88GT's Avatar
Yea it would be accurate but I would think it will be more accurate with a micrometer.
Tims 88GT is offline
Old 02-18-2006, 12:43 AM
89chatofive0
89chatofive0's Avatar
ORIGINAL: JD1969
this is my third engine build, but last two were stock master kit rebuilds. no plastigauge, or mics used for it and truck is still running after 15,000 miles.
89chatofive0 is offline
Old 02-18-2006, 02:30 PM
89chatofive0
Here are the pics of my parts.
Old 02-18-2006, 02:32 PM
89chatofive0
first pic is of gasket kit. second pics you can see my maifolds.
Old 02-18-2006, 02:36 PM
89chatofive0
are of the block crank and pistons.
Old 02-18-2006, 06:39 PM
89chatofive0
Default RE: Summit Rebuild Kit Arrived. New Pics Hell Yeah!!!!
asd
Old 02-18-2006, 08:51 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
ORIGINAL: JD1969
It can vary due to the type of lube used on the main and rod bolt threads. For examole if you use ARP moly lube (as is recommended) the amount of torque is less than what is required if you use oil as a lube. Used correctly plastigauge is fine, but I still would use a mic on my stuff.
JD1969 is offline
Old 02-19-2006, 01:16 AM
tinman
tinman's Avatar
I've always mic'ed my stuff. Good to know what things really are......
tinman is offline
10-26-2015 05:01 PM
Dathan
10-05-2015 05:52 AM
Drastang
09-30-2015 03:48 AM
marc954
09-29-2015 03:05 PM
marc954
09-25-2015 06:48 AM
Quick Reply: Summit Rebuild pics
