car wont start
car wont start
Just did 5.0 swap....is 93 engine in a 91 car....have got fuel pump running but cant get any spark....Is there anything that i missed...??? Because of the different years will this be a problem????Pls help......
car wont start
Originally Posted by ohsoquik02
did you hook up all the connections? how is the cap and rotor? what about the module?
Yep, well as you already read i got it runnin....was a bi7ch...i had a bad ground at first and then other problems.....but now she runs.. but not very good....oh yah, another question.....the car is a 91 and the fuel pump relay was supposed to be under the seat, right???? there are the provisions for it but no relay...is just a cover for it.....and if you jump the wires the pump will run.....just wonderin where the relay was on the 91 4 cyl....i now have it under the hood, by mass air and it works fine with the 91 car.....thats weird.....</P>
car wont start
Yank the distributor and intake and put a carb and intakeon it.And then a1985 mustang GT 5 speed duraspark 2 distributor and boxwith the bronze gear for 45.00 bucks at the local parts store and never look back.</P>
I replaced my distributor last year and used this distributor (with a cast gear since mine isnt a roller block like yours) and it had a damn good advance curve on it stock i was suprised.</P>
car wont start
Yah, that is the plan later on.....but for now i am goin with the fuely.....I am goin to run for the summer and then next winter(i am not drivin a 5.0 in the snow again) i will do the carb swap.....</P>
car wont start
good suggestion, it is exactly what i would have said if i hadnt been so f*ckin busy the last few days. carb = <IMG src=smileys/smiley16.gif border="0"></P>
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
