Valve Spring Q
Valve Spring Q
Those anybody know, or is anybody out there using a B303 cam with factory springs. I ordeered a set of springs from summit, but if i can use the stock springs that came on the GT 40p heads I got I will return the springs i bought. 110.00 to much for a set of springs.
So anybody with spring experience, hit me back.
RE: Valve Spring Q
getting the right springs will be better in the longrun.
I used my b-303 cam with the stock springs for a year, and then I put new springs in for a year, and the new springs made everything feel more solid, there was less high rpm vibrations.
it raised the valve float to around 6k rpm
RE: Valve Spring Q
It felt that i would be pushing the line just a little. so the money is worth it if it will help avoid any big issues later.
Nothing wrong with burgin.
NOBODY BEATS BURGIN DODGE.
NOBODY.
NOBODY.
RE: Valve Spring Q
ORIGINAL: 89chatofive0
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
