also I was thinking. check your check valve and make sure it is holding pressure because if it is not than it will just send the pressurized fuel back to the tank. that would explain the long cranking it has to build up pressure to start.
i know the check valve is behind the alt on a fox, but i am not sure on a sn95. but check behind the alt. and you replace it like a valve in a valve stem for a tire.
