newbie questions
newbie questions
ill prolly get all razed for this post but, i searched and didnt really find an answer
i have a 94 5.0 and im looking to get a little more from it here and there as i can afford it
as of now i have a flowmaster 40 series catback, h-pipe with no cats, fenderwell intake, and UDP's
the headers will be added before it hits the road this year
wondering if i should go with equal length headers or just the normie shorties and what is the difference in performance between the two
or should i sell the h-pipe and get long tube headers and a new h-pipe?
and how would that be compared to the shorties
also what are some engine upgrades that are semi affordable and that can be done in the driveway with basic knowledge and tools
RE: newbie questions
the best thing you can do for your car, in terms of engine performance, would be a new set of heads. if i was you, i would hold off on the exhaust, as with that your gains will be slight. after you put some hi flow heads on there, all other supporting mods will have a much better effect on the car. plus then you will have the satisfaction that your 5.0 is genuinely faster than a stock engine, or a stock engine with exhaust work done. after the heads id look at gears, then chassis\suspension improvements.
If you plan on putting a blower or nitro on go with long tubes, but watch
out for street legal issues.
I dont think there is much difference in shorties or equal length unless your counting
tenths down at the strip.
As said before heads are the first step in beefing up the engine.
Putting 4.1 gears in is an easy way to make her accelerate faster
for not much money.
for not much money.
around 1000-1400 for a good set of new ones, depending on what brand you go with. used, they are a bit cheaper, but personally, i dont really trust many used auto parts that i plan on getting a good use out of
thanks for the help
looks like i should start saving up LOL
i got another question i just thought of....
last year i replaced the shocks but not the springs, this summer i want to drop the car 1.5", can i just get the springs or do i have to replace the shocks again?
ORIGINAL: keq
thanks for the help
thanks for the help
ORIGINAL: keq
