wats a compression ratio?
depends. do you want to run forced air induction? do you want to have to run on racing gas? etc..... any time you force air into a motor (turbo,blower) you need a lower compression ratio. all motor cars usually have higher compression ratios. plus, the higher the compression ratio, the higher octane requirement to prevent detonation. hope this helps a little.
<FONT face="Times New Roman, Times, serif" size=2>It depends. If you want to keep it naturally aspirated with out forced induction than the higher cmpression ratio is normally better. If you are running forced induction than normally a lower compression ratio is preferred to help control detonation.</FONT>
uberstang1
09-20-2015 06:42 PM
09-03-2015 07:14 PM
