newbie w/basically stock '95 gt - 3.55 or 3.73?
#22
RE: newbie w/basically stock '95 gt - 3.55 or 3.73?
GO WITH 3.73...I have the Ford Racing 3.73 in mine, it was and is again now my DD...had them in there when I was driving back and for to college too. Mileage was 210 one way on the highway and it was perfectly fine, got 26 mpg with a 5 speed.
#23
unless you've been trained and certified dont install gears yourself... the guy i had to mine is one of the best techs at the dealership and he has to redo mine...
#24
oh yeah and as for the speedo problem, just go with the flow of traffic. that is what I do but I do know what speed I am going. Here is how mine runs
speedo reading/actual speed
-30/25
-45/37
-60/45
-80/65
-100/85
-as for the rest the other guy was too afraid to go any higher...
-30/25
-45/37
-60/45
-80/65
-100/85
#25
they make speedo correction gears for 3.55s, i thought someone made them for 3.73 and 4.10 as well? I know usually they just say use the 3.55 speedo gear for the lower gears as well, but i thought i remember seeing gears for 73 and 4.10 also?
#27
I've got 3.55's and love them. It's a helluva improvement over stock. I would not install the gears myself. It's worth having a shop do it right or they will grind and cause problems.
After you do gears, get a larger MAF and intake and you'll be good. That'll give you pretty decent power gains and won't cost too much.
#29
yes, I believe it's the 23-tooth white gear for the manual and the 21-tooth white gear for the auto....I may have that backwards
check 50resto.com or some other place to be sure about which one to get.
