got fpr and gauge.
got fpr and gauge.
what should i set the fuel pressure at? i searched and could not find the info i need so spare me the lecture. my set up is as follows a 190lph fuel pump, 70mm throttle body 73mm mass air , e-cam, pro products upper lower intake with 1" spacer, 1.7 roller rockers, so what do you guys think? any help would be greatly apreciated . maybe someone could make a graph or reference guide for future newbs like me cause i know this question comes up alot.
RE: got fpr and gauge.
Finally got the rockers on ehh? Feel the difference on how easy it revs up?
Anyways, with the stock 19lbs I ran with 39 PSI.
I hear 37-40 PSI is good, It actually depends on the car and how it reacts.
you talking about the fuel pressure right? you have a gauge in the car right ? mine mounts on the fpr. i was kidding about the timing light. btw hows your supercharger install going?
Yea im talking about the Fuel pressure mines also in the reulator, so I braught a wrench and alen with me when I took if for a test drive and adjusted it to where I think it felt right.
Havnt got the SC yet, supose to be here Monday or tuesday, Im also still waiting on my Cal tube for my 42Lbs injectors from summit.
