high idle and part throttle hesitation
1984 5.0 carbed, was running great has 80,000kms on it. near the end of the summer it was idling high (1000RPM) all the time like the choke wasn't kicking down. but the choke wasn't on, when you are just cruising it's fine but give a little push on the gas and it hesitates (sputters) put your foot in it and it seems fine. i'm thinking timing, fuel pump, charcoal cannister,already did fuel filters and the gas is fresh. any ideas would be greatly appreciated
RE: high idle and part throttle hesitation
Maybe you need to clean some stuff really good, my old car was having that problem, it was throttle position sensor, it was really dirty and wasnt reading correct sometimes. I dont think thats the case here, but something is making air flow mess up, try cleaning some things really good.
i have this same problem on my car. 1984 5.0gt. it hesitates and stalls sometimes when i try and punch it off the line 1st gear. A friend tipped me off to not burnin fuel pr vacuum leak or that my engine wasn't burnin the fuel clean enuff. So im in the process of replacing my ignition(it was on the list anyways) complete msd kit plugs n wires coil distributor and all. if you figure out the prioblem let me know man.
kyle.
kyle.
yeah plugs and wires and all the ignition are on the list to do when it comes out of storage. Also going to take the carb off and clean it really well maybe replace it. new intake and valve covers as well hopefully find the problem it's either fuel or igition so just gotta eliminate stuff
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
09-01-2015 08:16 PM
